Auction Saiger's Chemical Package
Auction includes:
  • One gallon Eloquence NEW Product
  • One gallon OdorOxy NEW Product
  • One gallon Vengeance NEW Product
  • One gallon P-Zyme Eucalyptus Mint
  • One gallon P-Lime-Zyme
  • One gallon Saiger's Cide Lime Citron Odor Destroyer
  • One gallon Saiger's Cide Eucalyptus Mint Odor Destroyer
  • One gallon Super Sealer
  • One 6.5 pound Tub Tsunami
  • One 6.5 pound Tub Code Red
Includes 3 New Products!!!
Saiger's Eloquence Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner
A very unique Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner
Field tested by the Saiger Family for Quality Assured Performance.
With the combination of proprietary surfactants, wetting agents and emulsifiers designed to remove tough oils and soils commonly found in upholstery fibers, you will see improved cleaning performance! Saiger's Upholstery, Fine Fabrics & Wool Prespray can also be used on carpets and rugs where a lower pH is needed.
You will see incredible cleaning & brightening properties with Saiger's Eloquence - Upholstery, Fine Fabrics and Wool Prespray-Cleaner.
Saiger's Eloquence Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner. A very unique Upholstery, Fine Fabrics & Wool Pre-Spray Cleaner
Saiger's OdorOxy - Oxy Urine Odor & Stain Destroyer
Odor elimination with the power of peroxide and a true odor destroyer!
A unique high-powered Peroxide formula with a true Odor Destroyer! Not a masking agent, but a product meant to go after the urine and odor causing organic stains! With the power of Peroxide and our unique Odor Destroyer.
Designed for those cleaners who do not have the time for enzyme activation, and need quick fast results for their clients. Odor & Stain elimination oxidizers to remove organic stains & Odor from urine, blood, coffee, vomit, and much more.
A unique formula to eliminate unpleasant stains and odors in carpet, upholstery, fabrics and hard surfaces. Avoid using on Wool and Silk materials, and be cautious with natural fibers.
Saiger's Sauce Vengeance Acid Tile and Grout Restorer
With twice the restorative cleaning power of many others, Saiger's Vengeance Tile and Grout Restorer will help to bring old grout lines back to new! Vengeance removes soils and stains on grout and tile that have been neglected for years.
This product actually removes a very thin layer of grout, taking with it all hard water deposits, soap scum and efflorescence. Effective against rust, scale, mineral deposits and more.
It renews the appearance of hard surfaces such as ceramic tile and grout. These surfaces may be flooring, bathroom walls and/or showers. Not recommended for stone surfaces or highly polished stone which may not react well to acidic based products.
LOW ODOR FORMULATION: Our proprietary blend of buffered acids keeps this product very low odor for use in the toughest of environments.
HIGHLY CONCENTRATED: One gallon of Vengeance can make as much as 17 gallons of ready-to-use product. Compared to other acid-based cleaners in the industry, this makes Vengeance twice as strong, creating not only better results, but also a better value.
Retail value $353
Free shipping to lower 48
Starting Bid $175
Minimum Bid Increment $3
Auction ends Tuesday 11/10/2020 at 9PM EST/ 6PM PST
I don’t care, just add the going crap that no one can get! Especially if it free shipping!
Thanks everyone for your interest and bidding on these products.
@Lee Stockwell also thank you and congratulations. The product order was processed last week and will ship soon.
