Saiger's Sauce 1 is ready!
Grand Rapids, MN
Ok my carpet cleaning friends who have been patiently waiting.
Saiger's Sauce 1 is done! it is Ready to ship.
Take a look at our Webstore to place your orders.
If you intend to order larger orders of anything from my webstore such as 6 cases or more, please contact me direct and I will get a better shipping rate.
Thanks for your patience and your willingness to give the new Saiger's Sauce 1 a try :)
https://saigers.com/supplies/category/saigers-sauce-products
And there will be a number of free samples available at the Mikey's Fest in Nashville! :rockon:
You can request also a free sample from our Webstore (well it is one penny as can't get the webstore manipulated for completely free) and we ask to cover some of the cost of shipping ($4-10 pretty average)
Thanks again!
Grand Rapids, MN
Directions and Suggested use:
Be sure to mix with warm to hot and preferably “soft” water. Normal soiling with your best repeat clients will require far less product usage. We recommend experimenting to find what works best for you
Product is quick dissolving in hot water, another time saver! Use the supplied measuring cup and don’t store more than you need on your (hot) truck.
-Pump up or Electric Sprayer – 1 scoop (2 ounces) Saiger Sauce One to 1.5 Scoops (3 Ounces) of “Saiger Sauce 1” per Gallon of warm to hot water. Very severe jobs may require up to 3 ounces – 4 ounces per gallon. Test first so you don’t waste this valuable solution.
-Hydro Force Type Injection Sprayer – Dilute 8 – 9 scoops “Saiger Sauce 1” (16-18 ounces) per 5 quart container with warm to hot water, and meter at 8:1 setting. (If not using a metering tip, it is typically at 4:1 setting: THEN dilute only 4-5 scoops which is 8-10 ounces of “Saiger Sauce 1”).
Reactions: Todd Millar
Grand Rapids, MN
Description
From 4 generations of Saiger family cleaners, we bring you Saiger Sauce 1”. The highest quality, very economical, multi use prespray you can buy.
A unique product created by 50 plus years of cleaning experience and passion, astute observation and testing in real world cleaning situations. A “one product” to help with most of your professional cleaning needs on carpet, tile and grout, synthetic rugs and garage floors, stone patios etc..
Gentle enough to be your everyday pre spray or your Blue Bullet on greasy commercial work.
For best, long lasting results, we recommend the use of an extraction agent in your cleaning system such as Harvard Heavy Duty Extraction Rinse (still producing for Neutral 7 Ph range) or other Harvard Chemical Research Rinsing agents. www.hcronline.com
Slight Fresh Lemon Scent.
No NTA, D-Limonene, Butyl’s or other harmful solvents.
Grand Rapids, MN
With either pre spray method, for the best long lasting results, use an extraction agent such as Harvard Heavy Duty or other Harvard Chemical Research Extraction Rinses.
More Helpful Cleaning tips:
We highly recommend mechanical agitation of some sort in traffic lanes and high usage areas for deeper and quicker results. Do not rely on “wand scrubbing” to break the soil loose. This over wets the carpet and wears out your lower back and shoulders.
Chemical usage suggestions can be far less if you take our advice on the soft water and scrubbing. Trust us, take your time, pre vacuum, wear a big smile, a nice shirt and stand out from your competition with this great product and your passion!
For tile and grout we recommend mopping the product down to avoid splashing. Use the same dilutions as you would with a pump up sprayer and don’t forget to scrub the grout lines.
Thank you for Choosing Saiger’s Sauce 1!
We think you will find this prespray a favorite no matter how you use it :)
Consider adding Harvard GForce Booster and Booster Powder to your cleaning arsenal for another unbelievable cleaning experience!
FFA
PA
FFA
So if i put this on some greasy olefin or poly, i wont be emberaced right?? Jk, ordering!!
Reactions: Mark Saiger
Grand Rapids, MN
What is the RTU ph on this ?
The stronger dilution rate (higher recommended) were seeing 11 ph
Less scoops, seeing 9-10 ph.
When presprayed on the carpets was seeing below 10 in most cases in the 9.5 range, but in higher ph strength on the carpet around 10-10.3 ph
Fully extracted (even using the Harvard Heavy Duty rinse) seeing neutral 7 ph numbers.
The Harvard Heavy Duty liquid actually is conditioning the water and lowering the ph we found even though listed as high ph.
Other rinses work well too...but we have not really done thorough testing of fresh water rinsing. Our water ph can be high up here at times even after going through water conditioning....
One at a time people don't crowd, damn I just won 17 cases of trashed green or I would be up in that businatch.
Reactions: Russ T.
Ya the website gets hung up on no shipping method found even though there's only one method to choose from.
Northwest Arkansas
Mark, what do the boosters, that have to be ordered separate, add to the prespray? Enzymes, SP.... Butyl?
Also, if I only ordered one booster which one should I get?
Grand Rapids, MN
Is the system on over load?
Tried to order but got hung up in check out.
It might have hit overload for a little bit. But it should work and we have been testing again to make sure. And we also ran out of the 45 pound pails so if you were trying to order that that could have been one of the problems
Grand Rapids, MN
The booster powder is a powdered peroxide and if you were to try a booster I would recommend the g-force which is now in lemon scent and works really nice. And is a soy-based product that has been very effective for us
Grand Rapids, MN
Mark, whats the difference between the new blue powder pre-spray and the original saiger sauce?
Actually a number of improvement but also even safer chemistry.
And it just cleans better yet, has a nice hint of lemon...
And you can still boost it if you feel necessary with a sodium Percarbonate type powdered peroxide (Harvard Chemical Booster powder) and our GForce soy booster which is also now lemon scent.
Another big feature is easy use and mixing
Reactions: FFA and Bob Pruitt
FFA
PA
FFA
Whats the soy booster generally used for?
