has anyone ever used this 10" CYLINDRICAL T10 Dual scubber listd on the "janilink" webstie
http://www.janilink.com/t10-automatic-s ... oduct-html i cam across this machine and was considering a sebo, but sebo was not really designed to be used on wet carpet (scrubbing in pre spray) although many use it for that, a new sebo is $600 this one is $900 and is designed for wet use even has a solution tank think it may be a better choice check it out let me know what you think,
was also considering the unit from power flite http://www.powr-flite.com/product/14+in ... crubber.do? i think either one of these ( although they cost a little more) would be better than a sebo, a little heavier which is better but still light weight, and would not have to ever worry about it getting damaged due to use on wet carpets can even use on hard surface what are your thoughts and opinions
