we set the rpm's at around 17 to 17.5 I've filed the governor down inside the control panel and could go to 18, 19, or 20 rpm's if I wanted, but 17 is almost always where we run the unit.
Jeff got us a 3 to 2 reducer and all we did was take the
AT valve off and put the Bayco on using the existing thread . It was quite simple to do, the only problem we had was we had to take the lid off the tank in order to spin the valve around to tighten it. If you'd like I could email you a picture.
I don't know why yours was opening at 19, that's set to high. Ours almost always opens at around 17.5.
I just got back from a job and to answer your question earlier about what the vac gauge does at 100ft is this: At 100 feet of 2 inch hose the vac. gauge will hover around 17 and will drop to 16 with the wand off the rug. That is exactly what we want, no drag on the blower and constant suction all the time, no let down.
I have a feeling there's something wrong with your vac gauge, I know I replaced a few before we got it right.
Feel free to call us if you have any questions, were supposed to help each other right?
By the way our 2 1/2 hose will be coming in next wk. That ought to be fun. We are more interested in getting as much suction as we can because we dual wand alot, I will spend whatever it takes to get it right.
If your not dual wanding with these trucks then you've spent a lot of money for nothing as far as I'm concerned.
