Tom, since this is a plug for your product, why don't you go all the way and tell us a little more.
I went to your site and read the info.It does not specify how to use and seem to be on the expensive side.
Since we're all open to new products and methods, as long as they represent an improvement or are able to deal with different situations.
So why should one buy U-Turn?
Or the simple consumer question: As a cleaner, what's in it for me?
It's retail cost to professionals is $128 a gallon concentrate. It makes 128 gallons of RTU product. That figures to $1 a gallon of RTU product.
Application is simple. Saturate the rug, allow dwell time of 30 minutes as a minimum. Rinse out and wash as usual.
Scenario: If a 6' X 9' takes 10 gallons to saturate, then your cost is $10. Charge a buck, as we charge, or $54 for the treatment for that size rug and guarantee odor removal 100%! The treatment saves time and is effective and safe for the consumer and the technician.
I did a whole house earlier this year of wall to wall carpeting where a dog got sprayed by a skunk outside, and thereafter ran through the house rubbing his body on all the carpet. The client was pleased with the result of our cleaning and wrote a public review on our carpet cleaning company due to being extremely pleased. In this instance: The application of the mixture of RTU U-Turn was though a Hydro-Spray device off our truck-mount. The saturation of the product was not applied as intense as I would have done on a wool rug (both sides) in our rug plant. However, due to it's limitation of being a topical applied treatment, we were nonetheless 100% effective in this instance for the wall to wall top cleaning and odor removal on this skunk smell job. We sprayed evenly the entire carpet and let it dwell 30 minutes and started cleaning normally HWE to get the results.
For in home costs, our charge is less per square foot than area rugs done at our shop. Our charge for area rugs is $1 a sq. ft., on top of our washing cost. When doing wall to wall in-home our dilution is less of U-Turn done topically on the carpet. We charge anywhere between $0.25 - .050 for in home treatments for urine or skunk contamination.
Note: We do not guarantee 100% odor removal for in-home wall to wall installed carpet due to the inherent limitations of reaching the source of contamination. This is always explained to the client by us and they may option out of it if desired. However, most of the time the client will opt to do it. The reasoning is common: The cost of risk for potential failure is not much compared to the cost of replacement or living with an odor anyways. We are usually effective in removing the odor completely or knocking it down to an acceptable tolerance. We know that is true by always doing a follow-up to the service. We have been using it regularly in our in home service now for over 3 years.
I will bring some to the
Mikey's Fest to demo if we have some stinky rugs. Just let me know in advance.
