I haven't used PhotoShop Elements 6 or CS3 but I can comment a a few others. The right software for you really depends on what you're trying to do, how much you want to spend, and how much time you have to invest.
I have Illustrator, Photoshop, PageMaker, InDesign, all of which I barely or never use, Publisher and CorelDraw. Corel is, far and away, my favorite.
Publisher is cheap, easy to learn and easy to use. If you simply want to drop in a pic or two and add some text, as a page layout tool, it's a good choice. Some printers don't like to work with native Publisher files. 2007 exports PDF and hi-res bitmaps which is what you need for commercial printing. You can generate pdf's from older versions using a PDF driver like pdf995.com. I picked up a nice one at
http://www.neevia.com for about $50. On the down side, Publisher very is limited as a design tool.
I haven't priced software lately so don't quote me but Adobe typically runs several hundred dollars. Corel, last time I looked was about half the cost and even less for the upgrade. For the money, Corel in MHO is a much better deal.
Corel and Adobe products are geared towards professional users and the learning curves are steep. You're not gonna learn them in a few days. If you plan on using a commercial printer you'll need a little better understanding of the basics of printing. When it comes to putting material together you're only limited by your imagination and your ability to use the software. But, there's nothing in the software telling you how to produce the effect you want. To get the most bang you'll want to learn both a page layout/illustration package and a program to work with bitmap images.
So, if quick, easy and affordable is important, I'd take a look at Publisher.
If you enjoy a challenge, are seriously committed to creating your own material, want the most flexibility and you don't mind spending time, and maybe lots of it, to learn the software, I'd look at one of the CorelDraw or Adobe Suites.
I'm reasonably sure you can download trial versions. That's what I'd do, especially the more sophisticated programs.
