Spend the day getting Stoned with Albert and Mike
Art Kelley
Damn fine video Mike. I'm putting it in tile cleaning folder. Ya Go Pro. See if you can rent that house for Mikefest. I take two rooms and bring Bob. He'll have to be drugged to fly. He won't bitch if he wakes up on that pool deck overlooking Heather Locklear's house.
A
alazo1
It's always a good time working with Mike. Between his crew and us we did a ton of stuff in one day.
Thanks for the gig Mickey!
Albert
L
Lance Golden
Question for Albert... Do you use a weighted drive plate AND unicorn weights?
A
alazo1
Just a regular 25lb weight lifting weight. Sometimes I add a second one. I have a 50lb weighted drive plate but don't use it much. You could see in the video that the setup is pretty ghetto (but works great).
Albert
Reactions: Lance Golden
clean image
Carl Maddock
al, no deck?
with money mikey paid you on that get a deck with a matching drive plate
clean image
Carl Maddock
the part that goes between the pad driver and the machine.
I know thse machine have ability to go no deck(12 inch driver) , 17" and 20" decks.
How to you "run" your perimeters with set up?
I know you do good work...just asking
A
alazo1
Yes, I have a few different size pad drivers so decided to remove the deck.
As for the edges, I find that the first 3 - 4" of edges are usually untouched so I will start the first grit around there and feather as I go. For transitions, I usually run a few grits of diamonds and polish with a hand machine. However, you can get pretty close without the deck. Do you run all diamonds to the edge?. I'm always interested in how others do things.
Albert
