The other week mine was leaking and I thought I blew a hole in it so I rank it out of the van so I could see better. Fired it up only to find the relief valve was leaking. Took it apart and cleaned it up good, put it back together, problem solved. I should have looked closer before lifting it out. I installed a drain tube out to the side door and noticed a little moisture there today. Probably time for a new one.
