I got a call from a cust where i used stain zone to reduce a spill. she said that the stain was gone but now it had a pink ring around the area. What could this be residue? any suggestion. im going there tomorrow and check it out.
Fab-Set (Try at around 4 ounces to a gallon) or citric acid (1 cup to 1 1/2 cups per gallon) is avialable from several sources. You can even mix both.miksar said:Could someone please put a product name to acid rinse
sweendogg said:Speaking of chemistry fun.... I had a fun little stain caused by some moisture... O2 cleaned, but the orange/ yellow remained, tried some small spotters but knew I had to work a little advance spotting. Got the oxidizer out first.. turned it RED! Acid side spotter, back to yellow, reduced it and turned it brighter yellow.. ok acid rinse again, then quick dried it... Gone... I felt a little like a mad scientist. All I can figure is that the water stain was a result of the moisture interacting with a rubber exercise mat and as a result of the time and lord only knows how many voc's/ chemical reactions took place, it reacted with the indicator dyes in the carpet.
Scott or Shawn... or anyone who may have a lead, manufactures always say that certain carpets have pH indicator Dyes. Yet we as a retailer have never seen any product info indicating whether a carpet does or does not. It would seem like there is not a whole lot of information readily available to talk about these specific dyes from a chemistry standpoint. Yet it seems like these problems occur regularly and always seems to result in carpet mystery's. While alot of us know about and understand enough to correct the problems. It still seems to be a weak link in the industry knowledge base.
Steam Way Formula Dmiksar said:Could someone please put a product name to acid rinse
