Super spinner and carpet tile
Andy
No Where
Doesn't Matter
With the high pressure needed to run the spinner, is their any concern with using it on carpet tile?
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
We have run the CX-15 on carpet tile a number of times with no issues. Be sure to stay with-in the suggested PSI range for the tool you are using.
Be sure to preinspect the job. Carpet tiles that are loose, curling at the edges etc. are pretty common. You don't want to take the blame for a pre-existing problem. Moisture can make an exisitng problem worse.
We've never had an issue using the Zipper Super Spinner. Carpet tiles or anything else. :cool:
