I know a lot of here own a SuperStrap but you still may not know all the things you can use it for. And of course some of you may have never seen one. So here it goes
One of the things that I find most useful about it is when your cleaning stairs you can eliminate the downward drag when your cleaning by using the SuperStrap to hold your hoses to your waist. It makes cleaning stairs easier.
This is also nice when cleaning upholstery. It keeps your quick connects from dragging on the ground and makes it easy to move quickly and and easily.
It can also be used instead of a stairhook.
It holds 2 inch and 2.5 inch hoses.
It can also be used to carry up to 100 feet of vacuum and pressure lines at the same time.
or hang them in your van
