May 14, 2014 #1 C C&S Member Joined Jul 16, 2013 Messages 112 Location meadville,pa Name Scott Who has changed one? New one I got does not fit at all. Sent from my HTC6435LVW using Tapatalk
May 14, 2014 #2 J Scott W Member Joined Oct 16, 2006 Messages 4,061 Location Shelbyville TN Name Jeffrey Scott Warrington They fit very tightly. Put it in some hot water to make it more flexible and you should be able to stretch it a bit and get it on easily.
May 14, 2014 #3 packfancjh Member Joined Oct 22, 2007 Messages 2,551 Location Sparks NV Name Chris Hagen I usually use a heat gun to get it to stretch enough to slide on. They are a tight fit
May 14, 2014 #4 Clean Response Member Joined Jan 21, 2008 Messages 790 Location Colorado Springs Name Brad Gouveia very tight I used a screw driver and a hammer to make mine go on.
