THANKS CARBONATED SOLUTIONS
I got my samples as promised unlike some others here. But some questions , the directions are only for a spray bottle spotter. I would want to use it for a bonnet cleaning solution. How much to use in a gallon of water? And it only comes in packets? No 6 pounders or buckets of the stuff?
Haven't used it yet but the citric acid component I used before and it's known for stickyness and resoiling.
Rieta Ebberts
The samples are for the 32 oz. squirt bottle size. I will send you a larger sample to try for a bonnet cleaning solution. We do sell it in a "bulk" format, but keep in mind that it is VERY reactive to all moisture, and that includes humidity, making the bulk a little inconvenient if you aren't diligent about keeping it tightly closed. The half case box of bulk is about 10 lbs and makes about 50 gallons of cleaner. 1/3 cup per gallon of water is the ratio.
Citric acid can be sticky, but our chemicals are balanced to prevent that. You will also find as you use it that resoiling is not a problem at all. There's nothing in it to attract residue, ALTHOUGH, until our product has broken down any other products that might be in the carpet, it may take a time or two to really notice that.
Looking for cheaper alternative to those EXPENSIVE 95% water EnCap ScamPoos.
But no hurry I'm using Hardballs power powder that has been sitting on my shelf for 10 years. Came in a two gallon jug and only uses 1 oz per 5 gallons. Works damn good with low residue and I add a cup of fresh lemon deo from bridgepoint to make it smell clean.
One ounce per five gallons and you thought you could do better?
Never heard of a chem that works at that dilution
