Fixing hack job. Tennant had someone local clean and moved out, I'm now cleaning it for the landlord who knows what clean should look like. Don't have a good pic of upstairs but it was loaded with soap.
Sent from my HTC6435LVW using Tapatalk
Looks like a porty $9.99 per room job that probably turned into $165 after there "special" treatment.
This week I have been following up after a company that really has a good rep. in the area.. The prop managers called me and say the carpet smells real bad can you come over and re-clean it. So I took my moisture meter, and black light in to check for urine and the moisture meter went off(fast beeping) in the entire unit!! This unit like the other two I checked were cleaned a WEEK ago!!
I told them I wouldn't clean them(except the one that the people were moving in the next day(they use some stinky deo also) until I can dry out the pad. I started floating the carpet yesterday at 5pm and checked it today at 4 and I'm still finding a LOT of wet areas!!
I ran the AC on high also, maybe a dehu would have made more sense, though I thought at the time it would be over dramatic. He runs
butlers..
I have no clue what this guys process is, but wet for a week? How is that even possible?
