Leslie Judson Jones
- Joined
- May 12, 2007
- Messages
- 2,242
k]http://www.youtube.com/watch?v=i24FNkSoIfkk]
k]http://www.youtube.com/watch?v=foWYX2OrRtYk]
Haven't had to change a belt yet but the bolts on the blower are very easy to access.Loren Egland said:Suggestion: Why not run oil hose through the fresh water tank like the Powermatic does? This would keep the oil much cooler in hot weather and probably lengthen engine life. It would be simple and trouble free as well.
Not mentioned: I watched Duane Ouxley's Dominator video and he was showing how easy his machine was to change belts. He even had a nifty pumpout option that could be belt driven as I recall. Is the C-4 belt change as easy?
Ron Werner said:is there any issue of that oil hose degrading in the water? If it ever leaked you would have a real mess.
Ron Werner said:depending on the coils you would have a huge drop in temp of the oil by the time it returned to the engine.
:shock: You been talking to my grandma ?meAt said:Ron Werner said:depending on the coils you would have a huge drop in temp of the oil by the time it returned to the engine.
welp, I s'pose so, but I don't know what that has to do with fly's knees.
