ACE
Has anyone tryed this?
From Steam Actions Website: http://steamactionsupply.com/index.asp? ... &ProdID=79
The Pulse Generator is a unique device that will provide your cleaning tool with aggitation through the pulsation of water. The Pulse Generator in the picture has been installed on a wand. We are selling the Pulse Generator as a seperate unit which you can install on a wand, tile tool, rotory tool or put QDs on and attach it to all of them. If you currently use mechanical aggitation before using your wand to clean with, then you may not see a big difference in the results, but you are likely causing pile distortion or carpet fiber damage. If you don't aggitate before wanding then you will be able to see and feel the difference the Pulse Generator makes. The biggest difference will be on medium to heavily soiled carpet. Aggitation without pile distortion or carpet fiber damage. The Pulse Generator does reduce the psi at the wand by about 150 so if you normally clean at 400 psi then just turn up your pressure to 550 psi. Heat makes a BIG difference on the operation of the Pulse Generator, for instance, when you start a job and your machine hasn't warmed up yet, you will not feel much vibration but when the heat hits the wand you will definately feel, see and hear the Pulse Generator working FOR YOU!!!
