What I want to know is how long did it take for you to be able to stand upright after being on you knees that long? Getting old sucks. I spent the day putting up a shed in the back yard and now my neck and knees and back are toast
The tool uses so much water because it is a tool that can be set as continuos flow and we use it like so. Rarely will we repeatedly hit the valve on each pass. We just set it with the slider for continuos flow and start to clean.
I think if a guy lowers the water output to much then it can not wet out even leaving a streaked appearance, increase the water flow pre treat then rinse.
nice job Mike! I was thinking you were gonna clean the borders first then do the center. Thats how I usually do it.
