Lee Stockwell said:
A trickle back circuit needs to be used to keep water moving at the valve, otherwise during short periods of inactivity the water at the valve will not be hot enough to trip, while the HX a few inches away could be a rumbling volcano.
Shane T said:
I believe Robert is looking for a fail safe relief valve to install at the end of the exhaust heat exchanger. In the event of of diverter malfunction it would open and discharge high pressure solution. I would suggest that you get to the root of the malfuntioning diverter. Adding another devise to control will probably just cause more breakdowns.
My PowerClean diverter has been very reliable except as I mention in my previous post.
If you really want to add another relief valve, you could install 12 volt valve and another adjustable thermostat like what is already on the front of your machine.
Edit: Just did a quick search and couldn't find a valve that would take the temp and pressure needed.
Lee....there is usually water flowing, at least a small flow. When I use the upholstery tool is when it seems to "not divert" , allthough I use a PC tool with bypass.
Shane....this Genny is 6 years old, and runs fine...most of the time. The diverter malfunction is one of those "you never know when" problems. I've changed solinoids, new battery, it charges just fine, but it still just decides on it's own when it wants to malfunction. If I am constantly using the wand, or 2 wands, there isn't a problem. I just hate running out to the van and finding the temp guage at 300*....there goes the QD fittings. If I can get a small divertion right at the outlet when the solution is getting up over 240*, it would keep things cooler. I would notice the divertion while using the wand because the pressure would drop some, and the temp wouldn't climb over 240*, or what ever the relief valve is set at.
This would just be a time saver, since I wouldn't have to run out to the van and drain off the heat.
