This is as easy as it gets guys...
Al
Wow, that's smooth! I want one.
Primarily HWE but I never Knock any of the lesser methods
:D
Jerry
Is that the Brute without the tank or something new?
Jeremy
Jeremy
looks like a conqueror ON A BRUTE STYLE FRAME.. sORRYabout the caps lock...
Dude that noise isn't from the machine..that rattling is comin from yo brain! :shock:
:lol:
Fred Homan
Do you think that the weight of the machine is needed when padding? I've done a little spot padding with an Oreck 13". Seems like it coud be better.
XTREME1
Greg Crowley
I like that Gem on your website. Too bad I don't know enough about that sort of cleaning. Got hosed with my Host
John G
Richard the 17" is the ideal size for residential.
Greg, yes I sell the GEM except every time someone is going to buy one I show them what the OP can do, and they buy OP instead.
Side by side a million times and the CRB will not clean anywhere near as good as OP does.
Blue Monarch
Dirk Wingrove
Which type pad do I buy if I'm a scrub and run (not changing pads) type encapsulator?
diamond brian
I accidentally backed a van over my 17" floor machine and now it has the OP movement. Works great--much cheaper too.
John G
Dirk, fiber pads would probably work the best for scrub and run, greenstripes work well too.
steve frasier
steve frasier
you came out with that thing right after I bought a conqueror machine from you
I will never forgive you for that :wink:
