Throttle control...
Able 1
Wi
Keith
My throttle is slipping when it's locked is there a way to tighten it? My TM has about 2,700 hours, is it time for a new one if so where can I get one (would like a turn throttle)?
Thanks..
damion68
I get mine from nappa truck/marine stores. They usually have them in stock and are about 1/3 the price from interlink.
C
Chris Sheldon
The Napa # for the throttle cable I get is: 731-1103. Last one I bought cost $36.98. You will probably have to trim it.
The cable from Prochem is a bit more stout I think, but the Napa one is cheaper and should last a while if you don't abuse it.
Shane T
Waukesha, WI
Shane Tiegs
Chris, what is it that we do that might be abusive concerning these cables? Is there something we should do to better maintain them?
C
Chris Sheldon
Shane, usually people turn the handle too hard to lock the throttle in.
The best throttle I have seen is the one Power Clean puts on their machines; they are a bit pricey, but very nice.
jimn
Thanks Chris, It is an aircraft type throttle, expensive but high quality. We have been using them for over 10 years now.
They are $99.00 or somewhere in that range.
C
Chris Sheldon
Jim, if Keith buys one I will be expecting a commission check!
