Living The Dream
- Joined
- Oct 25, 2016
- Messages
- 3,222
- Name
- Swani
That would be pretty sweet but I think the need for a bigger forced air unit is needed for recovery heat when opening and closing the door in sub zero temps.anyone thinking about what kinna heat to put in a shop....
look no further....get an
infrared tube and hang it on the back wall
cents per day to make you put little umbrellas on yor beers......
Exactly what my plumbing and gas fitting guy told me. Gas radiant heating is the way to go. It radiates heat, and warms the objects in the shop, and that way, when you open the overhead door in the winter, the objects radiate heat back into the air. Forced air only heats the air, and has to re-warm that same air. That’s why I’m going that route for my new shop.infrared heats the objects in your shop...not the air
so any air/heat lost would be insignificant.....
Gas for me this winter.
Good suggestion Bob!! I am putting in an auxiliary garage in at home and want to use it as a work shop. Any suggestions on brands?
AndMy butler will be parked in our non heated garage. The walls are very well insulated and I don't think we ever measured a temp below freezing in it, however I don't want to take a chance.
- Is there a switch that I can set to start a heater once the temp drops below, say 33 degrees?
- Will portable infra red heater, such as the link below, left inside the van do?
- https://www.homedepot.com/p/Dr-Infrared-Heater-Original-1500-Watt-Infrared-Portable-Space-Heater-with-Dual-Heating-System-DR968/205625429?cm_mmc=Shopping|G|Base|D27E|27-23_PORTABLE_HEATING|NA|PLA|71700000034238966|58700003946879293|92700031953708174&gclid=Cj0KCQjw3KzdBRDWARIsAIJ8TMQt6kiMVwppgvCGyUWJuI8c95WsgBNr_W27Xtyo7R-fZLQpBwVvvosaAqXcEALw_wcB&gclsrc=aw.ds&dclid=CK_4mb-Q2t0CFcb0ZAodOTAP0g
Should be fine. The switch you are looking for is the thermostat on the fan. Set it around halfway and it should go on and off periodically.My butler will be parked in our non heated garage. The walls are very well insulated and I don't think we ever measured a temp below freezing in it, however I don't want to take a chance.
- Will portable infra red heater, such as the link below, left inside the van do? https://www.homedepot.com/p/Dr-Infrared-Heater-Original-1500-Watt-Infrared-Portable-Space-Heater-with-Dual-Heating-System-DR968/205625429?cm_mmc=Shopping|G|Base|D27E|27-23_PORTABLE_HEATING|NA|PLA|71700000034238966|58700003946879293|92700031953708174&gclid=Cj0KCQjw3KzdBRDWARIsAIJ8TMQt6kiMVwppgvCGyUWJuI8c95WsgBNr_W27Xtyo7R-fZLQpBwVvvosaAqXcEALw_wcB&gclsrc=aw.ds&dclid=CK_4mb-Q2t0CFcb0ZAodOTAP0g
Yes, It is called a thermostatIs there a switch that I can set to start a heater once the temp drops below, say 33 degrees?
Lightbulbs at the key spots on the unitS And
Under if possible.Lightbulbs at the key spots on the unit
Because its only 4 for an hour.My insulated garage which house our
Hvac heater and water heater, never drops below 50°..
Even when its 4° out..
