Jim Martin said:for those fittings....marine grease (or aqua lube ) works the best.....just take a small brush and put just a little bit deep inside the female quick connect and around where the little bally things are and it will out last and out grease everything out there.....it is made for lubing parts that come in contact with water....and to displace the moister..it only takes a very little bit or you will have a sticky mess on you hands....
steve g said:[quote="Jim Martin":ymdn6e6f]for those fittings....marine grease (or aqua lube ) works the best.....just take a small brush and put just a little bit deep inside the female quick connect and around where the little bally things are and it will out last and out grease everything out there.....it is made for lubing parts that come in contact with water....and to displace the moister..it only takes a very little bit or you will have a sticky mess on you hands....
