We are putting the finishing touches on the new standard for 4-Vac portable extractors.
Here is the Titan QUAD with 500 PSI pump & the pump-out:
Notice enlarged 2" port on vac manifold on bottom left side.
Still has a fair amount of room in the compartment.
It has the new "M5+" exhaust port Cuff-Lynx with silencing system.
Starting current demands are less with this high-flow pump system.
Cord #1 draws 19 amps with 2 vacs and high-efficiency DC solution pump.
Cord #2 draws 18 amps with 2 vacs and pump-out.
Both are rated for plug-in power equipment with 20 amp circuits.
http://ccs5.com/zen/index.php?main_page=product_info&cPath=85&products_id=4904
It can also operate on two 15 amp circuits.
Larry
Larry
