prestige cleaner
- Joined
- Dec 27, 2008
- Messages
- 243
is there any stronger descaler than the one they sale at cc supply dis. currently using hydramaster seems to weak, I heard home depot sells one for swimming pools. would it damage my tm.
floorguy said:if its the steel coil on any system...wacth for "flakes" of shit coming off....they get stuck on the back side of the QDs and well...lets just say throw them away
i now run a filter coming right off my burner....
to bad they dont have a "better" filter type to run in HP systems.....that little strainer thing...is kind of a pita
meAt said:floorguy said:if its the steel coil on any system...wacth for "flakes" of shit coming off....they get stuck on the back side of the QDs and well...lets just say throw them away
do you flush your line at start up ?
and cool down at shut down?
it'll make a world of difference
stick a naked QD on the end of the sol line, put the line in the vac hose, go start the TM.
By the time you get back into the house, the line will be nicely flushed .
hook it to the tool and get to work
at shut down, turn off the heat, fill sprayers or emulsion tank, rinse off wand/tools etc
Zalan Szabo (zee) said:After that I take the hoe out with the pantyhose on it and start flushing it high pressure and low pressure back and forth.
ACE said:Zalan Szabo (zee) said:After that I take the hoe out with the pantyhose on it and start flushing it high pressure and low pressure back and forth.
