Here is where I stand. I have a EZ truck mount with a liquid cooled Carburated 28hp Kohler spinning a direct coupled tuthill 4007 blower. It has fresh plugs, air filter is fine ( ran with it out also ),
Coming off the waste tank I Y'ed the 2 2" ports to a stainless Y to a male cool cuff connection. With this set up @ 3,600 rpms it only show a 3hg loss threw that set up.
Now when 100% blocked off it boggs down 500rpms to the 3000-3100 rpms range when vac relief is set @ 11-12hg. The relief is the standerd brass-spring-bolt deal that came on Nicks older machines. When the lift is set higher it will bogg down further below 3,000 and keep getting worse and worse untill the wand is lifted off the carpet.
So whats the issue? Can I only run 10-11hg on this motor blower set up or wold a fuel issue cause this as well.
I'm just baffled. It just seem like the engine is not making enough HP to keep up with the higher loads. Nicks has been helping trouble shoot this but I'm still out of ideas right now. I also have a kunkle in my garage that I threw on for giggles. It's set @ 16hg and just about stalled the engine after 3 to 4 cycles on the relief.
Also. Should I move the rpms up to 3,600 when all is connected or before the vac hose is attached to the port? Maybe it's just a throttle adjustment issue?
