To meter or not to meter?
Josh Almanza
Josh Almanza
I’m using a hydro force to put down my ps and using with the yellow tip(8:1) seems I’m using a lot of ps to mix at this ratio(8-9scoops) will removing the yellow tip save on my chemical usage?
Andy
Doesn't Matter
removing the metering tip changes your ratio to 4 to 1
No it will increase if you keep outing the same amount of Chem into hf.
