Tornado High pressure 1/4 " solution hose to craftsm 300 psi
Weebco
Houston Texas
Gary Wiebe
How would I hook up my 1/4" tornado high pressure solution hose to a craftsman 3000psi pressure washer, I tried to find reducers etc, to no avail. I want to qc the 1/4 " male side of the tornado hose to the discharge side of the pressure washer!!!!!!! Nothing fits.
okccarpetman
try calling a pressure washer place in your town.. they can help with everything.
james
____________________________________________________
abc carpet care llc
AMERICA'S BEST CLEAN everytime!!
if you're unable to simply change the QD on the pressure washer to CCing QDs, you'll have to make your own adapter by buying a QD fitting for the PW, then adding a nipple (a short piece of 1/4 brass threaded pipe) and to the nipple will go a QD compatible with your CCing hose
The other way is simply put a pressure washer QD on your tornado hose.
But you'll have to change back and forth when you want to clean carpets.
Make an adapter and you won't have to monkey around changing QDs back and forth
Dallas, Texas USA
Re: Tornado High press 1/4 " solution hose to craftsm 3000 psi
Gary;
Pressure washers use ST (straight-thru) couplers.
Either replace the QC's or make adapters.
We use ST stainless fittings on our TM internal plumbing.
Regular shut-off QC's on the solution hoses.
Larry
