Jul 26, 2007 #1 J Johnnyone Member Joined Oct 8, 2006 Messages 185 Now has adapters available for the 2.5 Vacuum Hose to fit to your waste tank for High performance water recovery. If you also want add a stainless steel prefilter that will fit a 2.5 inch hose they have them available too. Thank You Larry Cobb
Jul 27, 2007 #3 Ron Werner Member Joined Nov 25, 2006 Messages 8,726 Location Sooke BC, Lower Vancouver Island Name Ron Werner are those a good 2" on inside diameter? I went to the twist cuffs to eliminate that bottle neck created by the hose connectors. I need a 3" to 2.5", then a 2.5" to 2".
Jul 27, 2007 #4 J Johnnyone Member Joined Oct 8, 2006 Messages 185 If it was a barbed fit on the 2.5 in it would be better It is a 2 inch on the OD and less inside Ron do they make a kool cuff reducer to fit a 2.5 to a 2
