Truckmount truths...
comments please...
There are several truckmount lines built by corporations that follow EPA and mandated safety guidelines. Some of these companies have distributors and suppliers who will install and maintain the unit for you. They typically offer extended warranties and additional technical support beyond what the supplier offers.
Other companies sell directly and provide proprietary parts and supplies. However, you'll need to do the work yourself or hire a mechanic. These larger companies advertise online, in industry trade magazines, and attend industry trade shows and Customer Appreciation Days at their distributors. Public perception is crucial to these companies, as is providing quality jobs to assembly people, engineers, management, sales staff, technical support, and more.
There are also many small manufacturers across the country who build truckmounts of various designs. They do not advertise and rely on repeat customers or word of mouth. Customization of components and lower costs can be positives, or perhaps they are within close proximity to you and can offer convenient maintenance. You’ll likely be dealing directly with the owner in most cases. Due diligence is essential with these operations, as there is not much recourse if things go south and the owner becomes difficult to work with.
Consider how easy the machine is to work on and who will be doing the maintenance and repair. Does the shop you are purchasing the unit from have qualified mechanics? Make sure to do thorough research on this subject, as many shops do not. Small engine repair and farm equipment repair may be your only choice if you are not capable of doing the work yourself.
comments please...
What is the purpose of this content ?
For public consumption:
If you find the need to create content that is of a "Consumer Warning" type, I can share two things that I think are important for cleaners to note when buying used equipment:
1. Transfer Flow, the maker of the fuel tap kits for slide in truck mounts, no longer makes these kits for trucks older than 2017. I have talked to two different people who bought used truck mounts in the last 30 days who had bought a used van separately, and now have to go through some engineering headstands to use their older trucks with these units safely. Without dating your content with a specific reference, it might help to mention that any van purchased for a truck mount's use should be first checked that it has the needed space available, weight rating for all the equipment, including water tanks, reels, portable equipment, overweight cleaners, etc., and that it can have a safe, legal fuel tap system installed.
2. Availability of parts. In a few instances this year, we've had cleaners whose truck mounts have been rendered useless due to important components no longer being available. We rescued two of them by tracing down used parts, but this alone cost excessive down time, and for a few, there was no alternative but to scrap the unit.
roro
Wellington
Ross Craig
No2 is a pretty good argument for back yard builders who don't use proprietary parts
comments please...
I have two places I go, Greg Santa Clarita, Mitch Northridge.
Greg can get parts didn't stock them.
99% he'll poach parts from old machines.
Your up and running for a time.
Mitch has parts and the fix will last longer.
