Upgraded my pool filter to 2.5"
Blue Monarch
Dirk Wingrove
Man, is it nice to have an in-line filter again. No more clogged APO or crap to clean up when I dump.
Barely any restriction at all. When I hook up the filter, there Hg increase is less than one on the gauge.
I already had holes drilled in the bottom of the stainless mesh basket, but they were way too small. I drilled a bunch of large holes and man, what a difference. All the crap balls up at the bottom and the airflow remains excellent.
If you don't have the holes drilled in already, do it. You can get a lot more work done without changing your panty hose.
:D
John Watson
It shore nuff do make the difference. and it is so easy to maintain. I just went to a true 2 in inlet and before I hook up it is so easy just to look into the 2 in opening and you can see if the sock needs changing or not.
Lyman
Lyman
greenie, would your filter give me any more cfm then the modified butler one.
Blue Monarch
Dirk Wingrove
The pics aren't any different than Jim Martin's.
When I saw his, I knew I needed to drill bigger holes in the SS mesh filter.
