lust1kiddo said:
I also have the pmf external tool...i want something to control the spray better. I have never used an internal tool..they much different? sometimes i find that I need one that sprays a little wide so I can just mist the top of the sofa and get the dirt right off the fabric instead of pounding water into it..it just works better for me sometimes, especially with microfiber.
This is why I prefer the HK tool. The shearing action sends no water past the fabric and it blasts soil off the fabric. The teflon head of the HK tool makes cleaning any fabric very safe. It works fantastic on microfibre sofas. Its two flaws are a heavy weight and the holed
glide leaved lines on some fabrics which require brushing to remove. A little mod should fix that however.
As for the PMF tools, come on, why would I go to something that could possibly snag a fine fabric. That one PMF tool is so antiquated it shouldn't even be a consideration unless cleaning movie theatre seats, ie fabrics that can take it. 800PSI valve on an uph tool???? !!!
What I didn't like about the SS tool was it overwetted the fabric, the spray wasn't consistent, it sucked the fabric into the slot too much. Also the trigger lock wouldn't engage under pressure. For a $400+ tool, it was not very precisely made.
What I liked about it was the weight and length of the attached hose. Made it very flexible to use. The tool itself fit into the hand nicely. So, I liked the tool, just not its performance.
Ideally, take the HK tool with a teflon head, give it the lighter longer attached hose, make the HK tool out of durable plastic, or even use the HK flushing design with the SS tool design, and you've got a real winner.
