urine smell
KOOSER55
One of the apartment buildings has a really bad odor of urine in the hall way what do you suggest i put down to take care of the odor its commercial carpet
juniorc82
Jon Coret
if it is confirmed that urine is presant in the hallway spray it down heavily with an all fiber or acid rinse with a bit of a odor neuturalizer additive , give plenty of time to dwell. extract it with water only, then go back and do a light after spray with an enzyme based deoderizer rIght when you get done . I have used that method several times and always gotten good results. I think its your best bet since you cant replace the pad on glue down.
Hydrocide Odor Neutralizer by Bridgepoint
or Odor-Zyme or Molecular Modifier both by CTI
