Rex is right, but even with the blower model designation and the RPM, it is still insufficient to determine blower output in which to compare units with same blower designations.
Here's why....
Once a manufacturer of a TM selects a blower size/model, he can opt for customization if the quantities are sufficient. An example would be the double shaft that many
Hydramaster units use. Now that kind of customization has no impact on CFM. But another common customization does. It's called "high heat clearances". By utilizing a "shaved lobe" blower, the unit can withstand higher lift loads without overheating. Moreover, these same units are utilized to create greater exchange heat for blower HX packages, and the like. However, HHC blowers also do this at a detriment to CFM output the customer is never aware of. In fact, TM sales literature may declare the output of the standard blower, but the OEM underdrives and uses HHC to put those specs so far from the truth, it is ludicrous.
So in addition to Rex's recommendations to ask for:
Model
RPM
Also ask whether the blower uses High Heat Clearances or another modification from a standard unit, which might effect actual NET CFM.
Then do your own observation of entry and exhaust plumbing to determine if actual CFM characteristics are further diminished by poor plumbing design. Lastly, assess the vac relief valve to see how much CFM is lost through partial opening at normal cleaning vacuum lift levels.
