P
phenning
What is a preferred configuration for a portable...2/3 stage vacs in par. or 3/2 stage vacs in a series? And why is one better than another?
Err.....that would be putting them in parallel.Bob Savage said:And, there is a better way of putting 2 vac motors in series.
Instead of connecting the intake of motor #2 into the discharge port of vac motor #1, as all of the electric vacuum motor series connections that I have seen are connected, instead, connect the intake of each vac motor into a Y, and then connect the remaining vac port of the Y, to the single stack in the portable.
This will give you more suck and allow each motor to perform much better, and last longer!
Bob Savage said:Nope, air parallel would be each vac having it's own separate stack into the recovery tank.
The way I described, in series, is both motors discharge into open air, not one into the other.
The Y splits the two motors but draws from a single stack. Parallel takes 2 stacks.
