I cant stand using the on board hose on a upright vacuum for doing the edges. Should I buy a smaller vac for doing the edges or buy a back pac vacuum. What should I get?
Waldo
Not sure what system you use, but that 2" hose coming through the front door.....
It suks purdy dang hard : )
If you're using the 1.5 whip, you could buy yourself a one piece wand and cut it to your height specifically for the task, $30 plus shipping from here. Or get a two piece and hunch over a bit.
box trucks. Wait that didn't piss you off did it. I mean please don't sue me. I can jam stuff in a standard van with the best of demm!With all the "must have" equipment discussed here, everybody should have a van + a 20 foot trailer behind, attached to a secondary 12 foot trailer to carry it all.
Unless you run a high efficiency crew where it makes sense, just use the freaking 2" hose.
Vacuum edges? People do that?
Vacuum period? WhoTF does that?!?
Brian H. on Nate The Great's computer.............
What should I get?
Waldo
You can just use a shop vac plastic extension wands whether its 2" or 1 1/2" and your truck
