Vacuum Maintenance tip
For those who actually vacuum a lot, check your beater brush. I need to replace mine about every 6mths. The belts will stretch a bit too so replace them.
I just replaced mine on a job, darn if it didn't start bringing up even more soil!! Had to go over the room again. Instead of 2 1/2" of sand from a 200sf berber, I got an extra 2" of sand.
That's quite a bit btw. Makes all the difference between cleaning it once or having to return to do it again!
Jimbo
If you didn't vacuum so long on each job, they would last longer!!
