dgargan said:
Care to take a guess at this one. About 3 years ago when I was on the truck I was driving my 03 GMC. I went to start it one day and as soon as it fired it would shut right off. It took about 30 times before it stayed running. It did this twice in 2 days and never did it again. Now, 3 years later it has done it twice in two days for my tech.Fire up then shuts off just like you cut the key off. What would do this?
Your FUEL PUMP is on its ...LAST LEG..... thathurts
Next time it happens....Take a Hammer or a large wrench...&..BANG ON the bottom of the "Fuel Tank".... :shock:
"While someone is cranking the engine".........
Most of the time this will "complete the circuit"..and the van will start... :idea:
But it is TIME to REPLACE.... :!: "This is a COMMON problem with older GMC'S"...
ps..Have your mechanic check the "wire connector's" FIRST... :!: :!: :!: :!:
Sometimes...it is JUST corrosion from being exposed to the elements... !gotcha!
