Van windows..
Oklahoma
John
Thinking about looking at a new van... Like the vans with no windows on the side but in the back. What's everyone's opinion on that?? Could I cover the side windows and back with something or tint the side and back windows. Opinions please
Thanks
bob vawter
Grassy Knoller
La La Land
bob vawter
are you gonna let chimps back in and out driveways.....
tint is too gangsta.....
they make a wrap that you can see right out......
Grand Rapids, MN
side windows and rear windows covered with what they call 70 - 30 and print over top
Easy to see out of , not as easy to see into
rhino1
Evansville IN
Chris Bolin
You don't need rear windows for backing up. If you can't do it with the mirrors then get a backup camera.
A side door window is helpful to me when I'm at an intersection with an angle, but I've never had a van without a side window so I'm sure there are ways to cope without one.
Cleantechsk
western Canada
Dustin
I used that stuff on my minivan. Lasts about 3 years up here. They named it" vision print"
Newest van I ordered went zero Windows but back up cam ☺
Bob Savage
Dayton, Ohio
Bob Savage
Ford makes steel panels that will fit into the side windows, even if you buy a window van, that can be painted to match the van. You cannot tell it is a window van unless you stop and study the lines where the windows are.
Reactions: rhino1
rhino1
Evansville IN
Chris Bolin
I recently saw a van with a similar setup, but the panels had hinges and they could be opened all the way to access whatever was inside the van, I assumed it was a custom job, I wasn't aware the panels could be ordered. Good info!
Barry-QDCC
Jurupa Valley, CA - So. Calif.
Barry Rhoads
I used to use Chevy Astro panel vans with no side windows to look out. You just need to make sure your mirrors are adjusted correctly and learn to use them. My employees all had no problem driving around town with them.
No accidents Barry?
I think it would cause problems when switching lanes or occasionally when pulling out into traffic an not being able to look fully to the right.
We always order them with side windows, when we buy used and they don't have them we have the glass shop cut the panel out and install windows.
spot mirrors that stick to the OEM mirror .
I put mine in the upper inside corner like this
couldn't live without them .
i have them on every vehicle..either large, med or small size (depending on OEM mirror size)
Scott S.
PA
Scott
since my new van has windows im getting the internal window cages to keep people from breaking the window and stealing shit. My Ford van already had them installed when i got it. and a steel wall behind each of the front seats so if something happened you don't get hit with a tool.
