venetian plastered walls and smoke
Luis Gomez
Luis Gomez
Picked up a fire loss today and one of the rooms has venetian plaster. Any ideas on how to clean this? It was a grease fire. and the affected areas are the ceiling and about 2 feet on top of the walls. Thank You for your response. Luis
Luis
Normally I would say start with a chemsponge and remove what you can dry, but it being a grease fire you'll probably not get much, in fact it could smear.
You'll need a good degreaser and start from the bottom up to avoid a drips that might leave cleaner marks.
Keep moisture down to a minimum.
Soot has a way of evenly depositing itself across the surface, I'd check to be sure if more isn't affected than just those areas that are obvious.
Latest Auctions
