On January 2nd I called Greenie and asked him how I might "Tweak" my Genesis 56 to get more out of her with a few of the thing's I have heard about on "Mikey's Board", we talked about everything, and at the end it boiled down to,... "Start with the Wands"! "I"ll set you up a couple, ship them to you (for a 5,500 sq ft. I had to do on the following Saturday) and you let me know what you think of them". Come Friday UPS was a no-show and I was really looking forward to those wands so I called Greenie and he said not to worry, My Wife and I will drop them off at your job site on our way through too LAX to pick up a friend of ours from Australia.
Saturday morning I was at the the job site for about 15 minute's talking to the custodian about the New Wands I was going to test drive that day when Greenie and his lovely wife showed up along with the "New Wands" . A 16" 3 jet with Green-glide, # PMF703 16" and a 14" 5 jet with Green-glide #CMP14LPS , both are 2" "S" wands. He told me "up the juice a bit and test them out and let me know what you think of them and be careful with the 16"er its a "Man's Wand", "your going to know you worked the day after using it". They were on a tight time scheduled so they where off in a flash.
I tried the 14" 5 jet first on a loose lay that had always given me trouble, its wrinkled for some reason and when you put a regular wand to it, it binds and lifts the carpet so as to stumble your stroke at the wrinkles, well, I was impressed right off the bat, it flowed right over it "smooth as silk" and vac with the glides was great it sounded as though I had double the air flow at the head of that wand, to make sure I did a hand test on that 20' by 15' and sure enough it was dryer than with a regular wand , after that I moved on to some commercial glue down and went at, that wand worked out so well I couldn't believe it, no matter which direction I went, no wand chatter and no matter how much juice I applied it sucked right up, I was done at this sight so went to check the loose lay before I moved on to a 5,000sqft'er I had to go and do, about a half hour had passed and it was almost completely dry-"Yup shes a keeper".
Grabbed some lunch and rolled up on a the 5,000sqft'er glue down around 1:15 P.M., got set up and took the 16"er "Mans Wand" for a test run, again I was impressed right off the bat, great vac at the head, I could go in any direction and no wand chatter, I was done at 4:10 P.M. and I went upstairs to check the carpets to see how they were drying,.. I couldn't believe it, almost completely dry! I called the custodian to lock down the building and when he showed around 4:35 P.M. I told him to check the carpets, he came out to my van and said "you didn't clean that carpet you just vac'd it didn't you" - "its to dry", that is when I asked him " do you think I should buy the wands I tested out today" all I heard was "Hell Yes", "What a Difference"! And I can't agree more!
"It nice to find a product and a company that lives up to what you have heard about it".
If any one hasn't tried one of Greenies wands well you are really missing out, by far the "Best" ! "And the service is Equal"!
And "yes" I had to put "Tiger Balm" on my wrist this weekend.
Greg
Greg
