bob vawter
Grassy Knoller
anyone still use these......im makin' them now!
notice how worn the old one was....
if i had more time... the whole damn Steam Genie would be entirly....CNC!!!!!glenboy said:are u makin them wit the oillite bushing cuz i bought one from M,,,, AND IT HAD NO BUSHIND ??????
why is that?KevinD said:Learned many years ago with tech's and operators that did not clean out filters, the proper place for vacuum relief is at the blower not in the waste tank.
John Watson said:needs a sacrficial zink cathode...
bob vawter said:why is that?KevinD said:Learned many years ago with tech's and operators that did not clean out filters, the proper place for vacuum relief is at the blower not in the waste tank.
GeneMiller said:i need to replace mine, was thinking about Johns. He makes one out of teflon.
gene
if you THINK you need to replace them.......GeneMiller said:i need to replace mine, was thinking about Johns. He makes one out of teflon.
gene
Shawn Forsythe said:Conventional thinking doesn't always win out over evidential reality.
I've seen more blowers grenade from errant relief valve parts than blowers damaged by human error due to clogged filters.
At least a clogged filter gives an indication before failure (no wand vacuum/wet carpet/high vacuum gauge reading).
KevinD said:And...There should also be a safety devise preventing small parts from reaching the blower in the event of a failure.
yor machine is BUILT wrong if you can DO THAT!KevinD said:bob vawter said:why is that?KevinD said:Learned many years ago with tech's and operators that did not clean out filters, the proper place for vacuum relief is at the blower not in the waste tank.
Because putting a relief AFTER the filters in the tank does nothing to protect the blower in case the filters get clogged.
well DO YA PUNK?????bob vawter said:sooooooooooooo then Shawn....
how well do you believe the Steam Genie Waste Tank was designed?
