Many have probably done something similar, but just in case.....
Here is a spot that was from massaging oil. We cleaned this place last year, spot of course came right out, but no one told me there had been a bunch of massaging oil spilled in this area. It did wick back and no one called me about it. Went for the fix yesterday!
Carpet on pad and on concrete in this case.
We were using alkaline based cleaner for this.
For urine, would use acidic (or a plant stain). Alkaline based because of the oil and also the soil level in this case. You can also to prevent wicking sometimes put a non water based protectant on top of it too....helps to prevent wicking in some cases.
Always be aware of what is below you or you could end up flooding a ceiling below you if you get too carried away!
http://www.youtube.com/watch?v=_1WycVDgx0M
http://www.youtube.com/watch?v=LzRiXt5YLrw
http://www.youtube.com/watch?v=AduKgsIfa4Y
http://www.youtube.com/watch?v=FHZFvOPXEY0
http://www.youtube.com/watch?v=tA1fQ0yEjgk
If you do not have a water claw....go to the hardware store and get a floor drain trap until you can afford one. We call it the poor mans water claw. Will work when needed.
