water flow rate & PSI.
Anthony
For those using the high flow rates with wands...8, 12 etc...
what PSI are you using? does it stay the same as you go higher in flow?
Most leave it the same.
Every once in awhile I get a guy who is running low flow ie: 04 total, and high pressure like 800 psi, so I tell him to double one and reduce the other, every single time it's like wow, that works better all around.
I must add, some wands handle higher pressure better and safer, so you don't want to be to generic when you reference this stuff.
