How is your pressure at the tool? If it's low, the majority is flowing to the waste tank. If it's filling the waste tank with hot water your temp solenoid is most likely bypassing water to it.
The system probably needs descaled and the bypass screens cleaned.
here is the manual, see page 44 & 46. You will need a spanner wrench to clean out the temp solenoid.
