Merc. Water Pump- can I experiment with stop-leak additive?
Merc. Water Pump- Prochem 100a
I'm not getting good flow- I was wondering if I used some "seal softeners" like you would use in automobiles to stop leaks in auto-trannys and other pumps-
would I cause more problems-- any ideas on that?
It looks like I'll need to rebuild or replace my Mercury MC14 water pump. My pressure gauge moves from over 500 to zero every time I open the valve and I get 64 ounces per minute flow..
