rwcarpet
Would a 2.2 GPH demand pump on a 20 gal tank be enough to supply the genesis with water? I want to install a water holding tank.....not too big, cause room is limited....but I also want consistant flow and pressure (this pump is 60 psi) to feed the Cat pump, run the APO when it's on, and run the Kinetico water softener, all at the same time. I doubt that I use 2.2 gals cause I don't hold the wand valve open for an entire minute...it's off and on. I would feed the water into the tank by way of a float system to keep it topped off. Does there have to be and expantion tank with in this system??
here's the system......http://www.northerntool.com/shop/tools/ ... _200347991
