his profile says he runs a Steamway.
So there will be no concerns with HX'rs
(unless he's so unfortunate to own a 9100 :shock: )
I don't know if they run blower exhaust thru the HX'r
when dirty soapy water or foam gets sucked thru our blower
(usually cause we forgot to fully close the dump valve
We run fresh clear water thru it while the blower is running at operating temps.
Don't pour large volumes in fast...cause water doesn't compress like air.
Just a slow stream of water for a minute or two, then let it run for 10 minutes or so to dry
Giver 'er a squirt of WD or some other blower juice after if it makes you happy
your blower should be fine.
They're a very durable and tough component ...they'll take a lot of abuse
