let me know what you think, thinking of using pics as website content. pics were taken with iphone one hour after last coat.
Jeremy N said:When you guys strip a floor is it ok to use the TM to suck up the stripped junk? If not, what do you guys use?
dealtimeman said:Jeremy N said:When you guys strip a floor is it ok to use the TM to suck up the stripped junk? If not, what do you guys use?
dont even think about it! that should never cross your mind again. go and buy a 130 dollar shop vac and some squeegees.
i cant stress enough how importantit it is to rinse the floor untill the water in the bucket is still clear after you mop it. this is important if you want to get the floor the most clear ,shiny and the most depth out of the finish you are using.
most shortcuts or misteps in the process will more than likely show when you are finished.
MicahR said:Stop using stripper and dealing with the time and mess and get yourself a SquareScrub
Youtube it. Makes stripping a floor actually fun!
steve frasier said:Stop using stripper and dealing with the time and mess and get yourself a SquareScrub
Have you demo the machine? It doesn't solve tha many problems. It doesn't remove all the finish. You can achieve the same results with a maroon pad on a rotary.
I have started a chemical free wax removal program using this method
I want to hear more about this.
What's the best way to do it and are there circumstances where it doesn't work?steve frasier said:I want to hear more about this.
what do you want to hear
