Jack Zipper Zerkie
Went to my local interlink to get acid to clean the heat xchange. Sorry we don't sell it anymore. They did say to use white vinegar and mix 1-1 . .Thank you stopped at food store.
You can usually buy a double strength vinegar that's more effective. Table vinegar is 5% acetic acid, pickling is 7% and cleaning or double strength is 10%. Works great for me.Went to my local interlink to get acid to clean the heat xchange. Sorry we don't sell it anymore. They did say to use white vinegar and mix 1-1 . .Thank you stopped at food store.
Put some of that on your fries.Home Depot got 30% I’ve only used it in a pinch when I ran out of Acetic acid
Harris 128 oz. 30% Vinegar All Purpose Cleaner Concentrate VINE30-128 - The Home Depot
Harris All Purpose Cleaner Concentrate fresh scent (case of 12) - kill 99.9% of germs, control the growth of mold and mildew, and infuse your home with a lovely scent with this disinfectant spray.www.homedepot.com
Hi Brian - we have been taking down to about 10% for descaling t/m. is that similar for you?We buy glacial acetic acid 99%.
We don't use it for descaling as we don't really have a problem with scale build up . We use it in our cleaning operation, both on-location and in-plant. It does get diluted for most uses though.Hi Brian - we have been taking down to about 10% for descaling t/m. is that similar for you?
How exactly? Setting dyes? Urine rugs?We don't use it for descaling as we don't really have a problem with scale build up . We use it in our cleaning operation, both on-location and in-plant. It does get diluted for most uses
We buy it by the 55 gallon drum. We use it mostly for spotting and browning.How exactly? Setting dyes? Urine rugs?
That's good stuff. Make sure to premix it in a pail or bucket before dumping it into your water box, otherwise if you dump to much powder in at once you will plug your water box and fittings. Also make sure to have your temp dial set to high heat when you are circulating it through, otherwise it will divert and dump into your waste tank. I figured all these tips out the hard way.Prochem Truck Mount Descaler
Prochem Truck Mount Descaler removes hard water deposits from truck mount heat exchangers. Regular removal of scale buildup prevents clogged hoses and protects your truck mount's delicate components.www.jondon.com
I fixed it for you, because all carpet cleaners are idiots. Just look at all the Guru's in the FB groups. It's comical.vinegar for the coffee pot.
Muratic acid (if you're not a carpet cleaner, cause it ain't kid stuff) for serious de-scale
There's a new one everyday hahahahI fixed it for you, because all carpet cleaners are idiots. Just look at all the Guru's in the FB groups. It's comical.
Pass this on to the local interlink, please. (Frustrating!)Went to my local interlink to get acid to clean the heat xchange. Sorry we don't sell it anymore. They did say to use white vinegar and mix 1-1 . .Thank you stopped at food store.
