Got a call to look at some stains in new carpet (installed June 1) left from 2 kids beds with black plastic button type legs. No metal screws or metal present. The entire leg bottom and about 1 to 2 inches up is the same black plastic. New beds went in the same time of install. Carpet is a thick creme colored nylon Stain Master.
Appears that the stains are from some type of chemical reaction (off gassing) of the legs. Customer thought it was rust marks from humidity. She put folded up white paper towels under the legs 2 weeks ago. I noticed that the legs also stained the paper towel. Stains are yellow in nature with a bit of orange.
Tried to remove stains, started with alkaline extractor (customer had used some Nylac or Woolite carpet stain on spots) Made sure her items were nuetralized. Tried a rust remover even though I was sure it was not rust, tried Stain Zone and heat iron, No luck, then Red Zone and heat transfer, no luck. Applied Stain Zone to the stains and will check on Monday. I am sure this is a permant chemical burn type stain, but wondering if anyone else has come across this type of situation from plastic legs causing a stain. I am thinking there was a problem in the process when these legs were made. It is 2 beds that did the same thing.
Thanks,
Saiger's Steam Clean, LLC
Grand Rapids, MN
www.saigers.com
Thanks,
Grand Rapids, MN
www.saigers.com
